RonSom1976 Posted July 21, 2019 Share Posted July 21, 2019 Hello, yesterdays gig - I swiched to the preset of the next song. I felt, testing one chord, it sounds a bit strange (would be an own topic) - I had that before. So I switched off the device to reboot it - that already helped in the past. But, restarting, the preset was deleted completly. Any idea to prevent? Thanks ... Quote Link to comment Share on other sites More sharing options...
spaceatl Posted July 22, 2019 Share Posted July 22, 2019 Curious, it is not technically possible to delete a preset location. Do you mean that the preset location was initialized to a "New Tone" patch...basically a blank patch. A couple of thoughts... Are you 100% certain that you did not accidentally change set lists? Are you running with a PC connected with Edit running? Quote Link to comment Share on other sites More sharing options...
RonSom1976 Posted July 28, 2019 Author Share Posted July 28, 2019 Yes, it was a „New Tone“ patch suddenly - it sounded strange, I plugged the POD out and in - the saved patch was gone Yesterday I got another problem: Line6 Variax via VDI to POD HD 500 Yesterday suddenly the Variax gets the strings untuned (in digital mode). Last week suddenly a preset was deleted completly. Today, at home, no problems. - I run the device at gig for about 12 hours - - I connect the POD by iRigMidi with iPad to use SetlistMaker to switch the sounds - Any ideas? Thanks ... Quote Link to comment Share on other sites More sharing options...
spaceatl Posted July 30, 2019 Share Posted July 30, 2019 only thing I can think of is maybe SetlistMaker is sending a bit more over midi than you are wanting it too... 1 Quote Link to comment Share on other sites More sharing options...
