I'm having some weird issues after the Helix 2.80 update. My joystick is now wonky. I can no longer "push" the joystick in to open the model list when making or editing blocks. I have to use HX Edit or manually turn the joystick to go through every effect or amp I'd like to use. While not mission-critical it's annoying to have to turn the knob for 3 minutes until I get to the amps.
Any advice or experience with this issue would be greatly appreciated.
And it's not a DSP issue, I've tri
Check in the Global Settings———>Preferences
Check that Joystick Encoder it’s set to Model. This is the original behavior.
If it’s set to Selection, it is moving Left/Right while rotating, but you can still select Models if you rotate while pushing.
