heinlein3 Posted July 23, 2019 Share Posted July 23, 2019 (edited) I am a gigging musician and the G10 remote system is an answer to a maidens prayer - however, the point of failure is the power cord for the base unit which is a really nasty little micro usb plug which is so loose that it becomes a lottery as to whether the unit is going to work or not - surely there should be a much more robust plug than this - anyone out there with similar views? Come on Line 6 - you are better than this!! Edited July 23, 2019 by heinlein3 mis spelling Quote Link to comment Share on other sites More sharing options...
cbrillow Posted July 23, 2019 Share Posted July 23, 2019 I'd suggest doing a search in this forum. It's very easy to find others who've bitterly complained about this issue, as well as some helpful suggestions to minimize the chance of this disabling your unit. Quote Link to comment Share on other sites More sharing options...
heinlein3 Posted July 25, 2019 Author Share Posted July 25, 2019 thanks - will do Quote Link to comment Share on other sites More sharing options...
SeaRefractor Posted July 26, 2019 Share Posted July 26, 2019 Pretty much the Relay G10 Stomp was released to address the power connection and uses a setup like your other pedals. While I have the Relay G10, it would be great if a discount the cost of the transmitter was provided to customers to receive the new base since the G10 transmitter is the same in all the models of that series. Wouldn't mind sending in my older G10 receiver to receive this trade in discount. The other reason for the G10S is that you can manually set the channel instead of it being auto. This way if you have a couple G10S users in the same gig, you just make sure you don't use the same channel and you are all set. No need to worry about who's relay was turned on first and trying to keep the auto-channel feature straight. Quote Link to comment Share on other sites More sharing options...
heyman73 Posted September 26, 2019 Share Posted September 26, 2019 This is what I did myself!! Very easy and cheap!! Quote Link to comment Share on other sites More sharing options...
cbrillow Posted September 26, 2019 Share Posted September 26, 2019 A little description would be nice! Is that a regulator board you've added? Maybe a 9Vdc input to 5Vdc device? Quote Link to comment Share on other sites More sharing options...
heyman73 Posted September 26, 2019 Share Posted September 26, 2019 DC-DC Step down converter. Input 9v or higher/ output 5v Quote Link to comment Share on other sites More sharing options...
cbrillow Posted September 28, 2019 Share Posted September 28, 2019 Thanks -- that's what I was guessing you used... Quote Link to comment Share on other sites More sharing options...
LiamBlack Posted September 30, 2019 Share Posted September 30, 2019 I myself only plan to buy this system, I did not know that there is such a problem. I'll try to clarify in my store they have such wires, but more reliable. Quote Link to comment Share on other sites More sharing options...
