Changing parameters with pedal on Helix Floor 2.80 also changes exp1 parameter
katerlouis
I have a patch where I can blend 2 paths with a volume block up front. EXP1 controls the block on path 1 from 0-100, and on path 2 from 100-0; u get the idea.
Now when I want to tweak amp settings with my feet, by longpressing MODE, changes with the pedal effect the parameter I want to tweak, but also change the volume blocks assigned to EXP1, which makes changing the amp parameter useless.
I can't remember having encountered that behavior in 2.71, but am not sure, because I don't tweak settings by foot THAT often.
Is that a bug?
Or is it intended?
