Sign in to follow this
Meiannatee
2.80 Bug when controlling multiple parameters with footswitch
There seems to be a bug with assigning multiple control parameters to a footswitch.
Setup:
Assign a footswitch to toggle between 2 settings in a delay block:
(A) Low feedback + low mix
(B) High feedback + high mix
In Global Settings > Preferences, snapshot edits set to "Recall".
Problem:
Helix gets "confused" about the ON and OFF states of the footswitch. This typically happens when changing snapshots.
Description:
1) Select Snapshot 1. Press footswitch  > ON. Parameters set correctly to (B), footswitch lights up.
2) Switch to Snapshot 2. Press footswitch > ON as well. No issues so far.
3) Switch back to Snapshot 1. Sometimes this bug occurs: press footswitch again > it goes from ON to OFF, but parameters jump from state (B) > (A) > (B). Parameter states are (B) but footswitch light shows OFF, meaning states are reversed.
4) Switch back to Snapshot 2. Footswitch functions normally, with ON corresponding to state (B).
5) Switch back to Snapshot 1. Footswitch behavior still reversed (ON = state (A))
This setup was working fine before the update. It started after updating to 2.80. I've tried this on a new preset, same problem happens occasionally. But not always. Sometimes restarting the unit fixes it for awhile. Can anyone verify?
Well, when you use a footswitch as a controller, it doesn't necessarily have on/off states. It has min and max settings. Generally, the max corresponds to the footswitch being activated and the LED ring lighting up, but with snapshots, it's easy for things to get mixed up. One thing is that each snapshot can by saved with a specific value for that parameter outside of the footswitch state. So using this footswitch with the Snapshot Edits parameter set to Recall, you're actually re-saving the snapshot value whenever you use the footswitch. The footswitch is really just always going to toggle between the min and max settings. It doesn't really track with snapshot changes. That's been my experience, anyway.
Thanks for the reply. What I meant was, previously, the behavior was predictable as such:
Footswitch ON (LED ring lit up) = max settings
Footswitch OFF (LED ring off/dim) = min settings
Now, in the same preset, it could be working normally in one snapshot (like the above), but reversed in another (ON = min, OFF = max).
I know it's a bug because:
1) it worked in previous version
2) sometimes restarting the unit fixes it for awhile
Hope that clarifies the matter.
I can verify. It get's kind of annoying to have a "Solo" button, but your parameters turn down when your overdrives turn on.
I'll add, the only way I've been able to beat is when, let's say I want the level of an EQ to go up to provide volume during a solo, I assign the controller footswitch to the level and the min/max immediately goes to -60dB/+12dB, I have to edit the max first and then the min. Otherwise the on/off phase of the footswitch will be backwards from from what I want.
