jamesy121 Posted August 1, 2019 Share Posted August 1, 2019 Simply can you link a powercab 112 with a stagesource 3lt Quote Link to comment Share on other sites More sharing options...
ADBrown Posted August 1, 2019 Share Posted August 1, 2019 You can link the Power Cab 112+ with an L3t via L6 link. I did this once with my Helix, PC112+, and L2t to check out sounds in stereo and experiment with a wet/dry rig. Quote Link to comment Share on other sites More sharing options...
jamesy121 Posted August 1, 2019 Author Share Posted August 1, 2019 How was the sound, I just use the 3lt on its own sometimes through the pa and was wondering if it would be worth adding the Powercab, I am a guitar player with a band..drums and bass, small pubs the 3lt on its own is pretty good. Can you use other powered speakers with the 3lt or are you tied to line 6 Quote Link to comment Share on other sites More sharing options...
ADBrown Posted August 1, 2019 Share Posted August 1, 2019 1 minute ago, jamesy121 said: How was the sound, I just use the 3lt on its own sometimes through the pa and was wondering if it would be worth adding the Powercab, I am a guitar player with a band..drums and bass, small pubs the 3lt on its own is pretty good. Can you use other powered speakers with the 3lt or are you tied to line 6 When I ran the both the PC112+ and L2t in flat mode it sounded pretty good. I also used PowerCab as my dry amp, and L2t for all my reverb, delay etc and that sounded great. However, I don't think I'd bother to do this live. Stereo effects/rigs don't always translate to the stage, and the L2t or PC112+ alone is enough volume for me. If I need more volume I just go to the PA. If you aren't set on using L6 Link you could use other powered speakers with the L3t using standard XLR connections. Quote Link to comment Share on other sites More sharing options...
