what is the diference of S/PDIF
redbelo
Every time you go from analog to digital or digital to analog there's a conversion (ADC/DAC) from a voltage based signal to a bunch of 0's and 1's or vice versa. Each conversion takes time (latency) and slightly degrades the signal, though whether or not that degradation is perceptible is a topic of some debate.
Guitar to Helix = 1 DAC
Helix to Line Out (XLR or 1/4") = 1 DAC
S/PDIF eliminates that second DAC.
FWIW - I can't tell a difference in audio quality, and consider the added latency to be negligible. YMMV.
ya
but how i do the connection ? from the coax or xlr to the optical that the APOLLO requires ?
3 hours ago, redbelo said:
what is the diference of S/PDIF and the line out ? I assume S/PDIF is digital , but isent the XLR digital  also ?  what is the diference ?
You may want to read this if you are not familiar with S/PDIF:
https://www.hardwaresecrets.com/everything-you-need-to-know-about-the-spdif-connection/
hope this helps / makes sense.
  • Upvote 2
