reamp with stomp hx and pro tools
anthdidj
I am running Pro Tools 12 and have set the playback engine to 'HX Stomp'.
Following the manual for reamping a DI track... I set the input on the helix to usb 1/2 and then I go to set up the output of the DI track to USB 5/6 however I do not see this as an option. I assume my I/O is not setup correctly? The in's work fine and I have recorded with the Helix into Pro tools which it automatically setup for me but doesn't seem to have assigned the outputs. How do I go about doing this?
Awesome that fixed the problem thank you. One more question... I only want to record in mono so do I set the output of the DI to out5 and reamp track to in1 or do I have to keep the output of the DI to out 5/6 (stereo) and just change the reamp track to in 1  (stereo out to mono in record?). Doesn't seem to change the sound of the re-amped track either way.
