G10 wireless does not like piezo?
logicbdj
Hi... Even with the G10T pushed all the way into my Parker Dragonfly guitar, I get no signal from my piezo bridge pickups.  Is this typical?  No problem in using a cable, but I often blend my pickups and prefer the G10 system due to its clarity.  Any advice?
Does your Parker have a TRS output jack? If so, then I imagine the piezo signal would come through on the ring connection. The G10T won't work with that, as it uses the ring for charging. You could try using the little TRS to TS adapter that came in the box. That would short the ring connection to the sleeve, so that may work.
On a related note, I have a transformer from Radio Shack (The Source) that's about 3-4 inches long... you plug a 1/4 inch and it's end is 1/4-inch.  When I use that in the guitar (along with the G10T) it works fine without any high-pitched hum.  And so, although a bit of a long thing sticking out, it works.
Yes, the guitar does have a TRS... it includes a cable that allows you to split the signal to two different amps.
