Danilojog Posted August 8, 2019 Share Posted August 8, 2019 Hello Good morning, I have a line 6 stagescape m20d digital stereo, and I need the wifi adapter. Can you tell me if any usb wifi on the market works? Thank you Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 8, 2019 Share Posted August 8, 2019 Here's the official Line 6 statement: Personally I use the Apple products and have never had a problem. Quote Link to comment Share on other sites More sharing options...
kvdm Posted August 22, 2019 Share Posted August 22, 2019 For over a year I tested different Apple hardware (I have a couple of different AirPorts and apple USB-network adapters). Notting worked, not even the equipment line6 advised. Last Month someone on this forum suggested a cheap Samsung wifistick sold on AliExpress: Search for WIS12ABGNX on AliExpress . For 12-15$ you have a WiFi-stick that works with the stagescape. It takes a minute to find and connect to your WiFi-network, but it does work and the connection is solid. Quote Link to comment Share on other sites More sharing options...
alfredo_biosca Posted October 8, 2019 Share Posted October 8, 2019 Hi There! I acquired 3 M20D, 4 subs, 4 L3t and 4 L2T recently. To achieve success connecting ipad to M20D wireless, I do do want to do double check about the supported/tested exact version of the APPLE USB TO ETHERNET ADAPTER and APPLE AIRPORT EXPRESS. I investigate over the product number and de UPC item and there are this options: 1) APPLE USB TO ETHERNET ADAPTER Model MC704ZM/A with UPC 885909439560... (this is the one Line6 empathize to buy) Model MC704BE/A Model MC704LL/A May the two other models really may not work, may you tell the technical reason not work? 2) APPLE AIRPORT EXPRESS. model M9470LL/A family # A1084 / A1088 802.11b/g or AirPort Express 802.11g (1st Generation) model MB321LL/A family # A1264 802.11a/b/g/Draft N or AirPort Express 802.11n (1st Generation) model MC414LL/A or MC414AM/A family # A1392 (802.11a/b/g/n simultaneous dual-band) or AirPort Express 802.11n (2nd Generation). Which one is the best for functionality / performance AND to be 100% sure they are compatible? DO YO KNOW: May a Apple Airport EXTREME work or may not work at all? Have you tested any?. Thank you very Much for your kind feedback! Quote Link to comment Share on other sites More sharing options...
stormstudios Posted October 9, 2019 Share Posted October 9, 2019 Airport Express - buy the 2nd generation. The 1st did not work for me and 2 seconds after buying the new one (this is years ago) the setup took 5 seconds. I think any Apple USB to Ethernet adaptor bought in the last three years will work just fine. Safest, easiest path is buy the latest of both. Quote Link to comment Share on other sites More sharing options...
