simmerswitch_ Posted August 10, 2019 Share Posted August 10, 2019 I have the HX FX. I want to swap the order the presets appear so that 001 preset is at the "top" and I select Bank DOWN to go up in numbers. Currently it is like this: 126 - 127 124 - 125 .... 003 - 004 001 - 002 I want it to be like this: 001 - 002 003 - 004 .... 124 - 125 126 - 127 What settings does this? HX Edit is in a descending order, so I really hope the HX FX can do it too. Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 10, 2019 Share Posted August 10, 2019 3 hours ago, simmerswitch_ said: I have the HX FX. I want to swap the order the presets appear so that 001 preset is at the "top" and I select Bank DOWN to go up in numbers. Hi, I don’t own a HXFX, but if you check in the Global Settings under Preferences > Page 2 > Knob 3 > Parameter = Numbering also in the Global Settings under Switches > Page 2 > Knob 2 > Parameter = Up/Dn Switch That’s what’s in the Owner’s Manual. I don’t know if this is what you want to achieve, but I hope it helps. Quote Link to comment Share on other sites More sharing options...
