CeSaRiOs Posted August 11, 2019 Share Posted August 11, 2019 Good morning! Version 2.0 of V Remote does not work for Windows. Installed on two different machines, also tried on Win 7 and Win 10, but does not open. Any solution? I use x64 systems. Quote Link to comment Share on other sites More sharing options...
Bert_Peters Posted August 11, 2019 Share Posted August 11, 2019 Sorry can't really help you, maybe uninstall and install again with admin rights? Works fine for me under win10 Quote Link to comment Share on other sites More sharing options...
CeSaRiOs Posted August 11, 2019 Author Share Posted August 11, 2019 Bert_Peters, I have reinstalled on two different machines with the right of Adiministrador, one with Win 7 and 10, and another with win 10. In both it gives error still at startup. Do you use x64 or x86 system? Quote Link to comment Share on other sites More sharing options...
CrovaxWindgrace Posted August 11, 2019 Share Posted August 11, 2019 Did you install the Asio driver too? it's not mandatory, but maybe we can give it a shoot. Also remember to update your DirectX and .net framework...just because everything that fails on windows its usually because of those two. Quote Link to comment Share on other sites More sharing options...
Bert_Peters Posted August 11, 2019 Share Posted August 11, 2019 2 hours ago, CeSaRiOs said: Bert_Peters, I have reinstalled on two different machines with the right of Adiministrador, one with Win 7 and 10, and another with win 10. In both it gives error still at startup. Do you use x64 or x86 system? I'm using x64, have you got the latest drivers, there was a update a while back. Quote Link to comment Share on other sites More sharing options...
gtrman100 Posted August 11, 2019 Share Posted August 11, 2019 What is the error message you're getting? Quote Link to comment Share on other sites More sharing options...
CeSaRiOs Posted August 12, 2019 Author Share Posted August 12, 2019 9 hours ago, CrovaxWindgrace said: Did you install the Asio driver too? it's not mandatory, but maybe we can give it a shoot. Also remember to update your DirectX and .net framework...just because everything that fails on windows its usually because of those two. I upgraded Windows 10 to the latest version, also the .net Framework and Directx, but it still doesn't open. The previous version runs normally. 3 hours ago, gtrman100 said: What is the error message you're getting? When it appears it just says that the program needed to be closed will search for a solution. But the spider almost always doesn't appear, it looks like it will and nothing happens. 1 Quote Link to comment Share on other sites More sharing options...
CeSaRiOs Posted August 12, 2019 Author Share Posted August 12, 2019 I upgraded Windows 10 to 1903, upgraded the .net framework and also DirectX to the latest versions and still the problem persists. Never had problems with Spider V Remote, until version 2.00 always rotated very well both on Win 7 as in Win 10. Quote Link to comment Share on other sites More sharing options...
bob_fat Posted August 15, 2019 Share Posted August 15, 2019 same issue here - installed v2.00 - it looks like it's going to start up and closes down with no errors. Can we run it in verbose mode to see why it's failing? Quote Link to comment Share on other sites More sharing options...
bob_fat Posted August 15, 2019 Share Posted August 15, 2019 I installed v 1.00 on the same windows 10 (latest update) - Works I Installed v1.03 on the same windows 10 (latest update) - Works I Installed v2.0 on the same windows 10 (latest update) - Opens, then closes after about 3 seconds. - no error I then In installed 1.03 on the same windows 10 (latest update) - Works No idea why its not starting Quote Link to comment Share on other sites More sharing options...
CeSaRiOs Posted August 15, 2019 Author Share Posted August 15, 2019 3 hours ago, bob_fat said: same issue here - installed v2.00 - it looks like it's going to start up and closes down with no errors. Can we run it in verbose mode to see why it's failing? I've already lost count of how many solutions I tried to solve, but none worked. 2 hours ago, bob_fat said: I installed v 1.00 on the same windows 10 (latest update) - Works I Installed v1.03 on the same windows 10 (latest update) - Works I Installed v2.0 on the same windows 10 (latest update) - Opens, then closes after about 3 seconds. - no error I then In installed 1.03 on the same windows 10 (latest update) - Works No idea why its not starting This happens exactly like this. I'll try to find a solution, any news we come back. Quote Link to comment Share on other sites More sharing options...
dimitarnc Posted August 16, 2019 Share Posted August 16, 2019 Hi guys, it is some bug in the application it seems. This is from the Windows event log: Application: Spider V Remote.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.IO.FileNotFoundException at WindowsCommon.EngineInterface.ParamValueServer.createEngine() at WindowsCommon.EngineInterface.ParamValueServer..ctor() at WindowsCommon.EngineInterface.ParamValueServer..cctor() Exception Info: System.TypeInitializationException at WindowsCommon.EngineInterface.ParamValueServer.get_Instance() at MainApplication.MainWindow.<.ctor>b__10_0() at System.Threading.ThreadHelper.ThreadStart_Context(System.Object) at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object) at System.Threading.ThreadHelper.ThreadStart() Faulting application name: Spider V Remote.exe, version: 2.0.0.0, time stamp: 0x5d3085bd Faulting module name: KERNELBASE.dll, version: 10.0.18362.267, time stamp: 0x91664cab Exception code: 0xe0434352 Fault offset: 0x00113442 Faulting process id: 0x8cc Faulting application start time: 0x01d5545c35e705c6 Faulting application path: C:\Program Files (x86)\Line6\Spider V Remote\Spider V Remote.exe Faulting module path: C:\Windows\System32\KERNELBASE.dll Report Id: 89b1034b-a4f0-4a8d-afdf-a6f897789674 Faulting package full name: Faulting package-relative application ID: So probably we have to wait for fix of this. 1 Quote Link to comment Share on other sites More sharing options...
bob_fat Posted August 20, 2019 Share Posted August 20, 2019 First look, it looks like it cannot find a file it needs, but its not being handled at all by the application when it cannot find the file. Just check in C:\windows\system32. To see if there is a file present called KERNALBASE.dll cant see any other references to any other files in the report. Quote Link to comment Share on other sites More sharing options...
bob_fat Posted August 20, 2019 Share Posted August 20, 2019 I just installed v2.00 on my daughters cheapo windows 10 hp stream laptop, and it launches fine. I checked and kernelbase.dll exists in system32 if its not that file, we will either need to wait for line6 to read this thread and tell us so we can install whatever software has this file, or try to find out what it could be ourselves. Quote Link to comment Share on other sites More sharing options...
bob_fat Posted August 20, 2019 Share Posted August 20, 2019 The kernelbase.dll version on my daughters laptop is 10.0.015063.1266 her laptop has not been updated for ages. Quote Link to comment Share on other sites More sharing options...
bob_fat Posted August 20, 2019 Share Posted August 20, 2019 Its nothing to do with the file kernalbase.dll missing, but it might be something to do with .net generating the error due to a vc++ component missing. i cant test this at the moment, but can you try installing C++ redistributable package for VS https://support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads please try installing this for x86 or x64 and see if it resolves. 1 2 Quote Link to comment Share on other sites More sharing options...
rp51730 Posted August 21, 2019 Share Posted August 21, 2019 Not sure if important .. got same issue under Win10 with latest version not working. Already installed Remote V 2.00 under WIN7 and works perfect. Raised a ticket to L6 about this ... Quote Link to comment Share on other sites More sharing options...
Random1643 Posted August 22, 2019 Share Posted August 22, 2019 Just to add my experience as a 2018 HP laptop running Windows 10 owner, I needed some help from Line 6 Support but once I got the right set of instructions was able to update to Firmware 2.0 with no problems. It runs fine. I love the option of using the Classic speaker mode. Great improvement! Quote Link to comment Share on other sites More sharing options...
dimitarnc Posted August 23, 2019 Share Posted August 23, 2019 On 8/20/2019 at 6:35 PM, bob_fat said: Its nothing to do with the file kernalbase.dll missing, but it might be something to do with .net generating the error due to a vc++ component missing. i cant test this at the moment, but can you try installing C++ redistributable package for VS https://support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads please try installing this for x86 or x64 and see if it resolves. bob_fat, you are the hero man :) I installed Visual Studio 2015, 2017 and 2019 x64 version and everything works now. I have lates Windows 10 x64 1903 up to date (23.08.2019) Maybe on old laptops all VC packages are installed due to long update history. This was not the case however with my fresh installed laptop. Now it works. Thank you! 2 Quote Link to comment Share on other sites More sharing options...
ThomasJaeger Posted August 28, 2019 Share Posted August 28, 2019 Hello, I have the same problem. Unfortunately C ++ is not the solution for me. I prefer Win 7 but also under Win 10 with all updates it did not work. The difference is that under Win 7, the old remote app can not be reinstalled if you have installed the Remote 2.0. Quote Link to comment Share on other sites More sharing options...
xpack Posted August 28, 2019 Share Posted August 28, 2019 Hello, I also have this issue. I use an old version to be able to use the Spider remote on my SPIDER V240 head. I think that application can be really improved. I have also and HD500 with DT25 amp and the software for HD500 is really better in term of configuration for exemple I cannot use my external volume pedal like with HD500. Also I cannot activate both effect with same button. I can understand that this product is less luxurious than HD500 but possibility are there..... I hope that Line 6 Will upgrade this SPIDER REMOTE software very quickly!!!!!! Please Line 6 support help us. Laurent Quote Link to comment Share on other sites More sharing options...
CeSaRiOs Posted September 9, 2019 Author Share Posted September 9, 2019 Good morning, gentlemen! Who had problems with the new version please open a ticket, who knows so Line 6 seeks to find a solution. Quote Link to comment Share on other sites More sharing options...
rommelnatera Posted September 25, 2019 Share Posted September 25, 2019 Hi guys! I downloaded the software to my computer, and also downloaded a couple of tones. I am trying to open those tones with the app, but it crashes every time and it won't let me use it. Anybody with the same issue? Thank you! Quote Link to comment Share on other sites More sharing options...
Hankon6 Posted October 9, 2019 Share Posted October 9, 2019 I too have an issue with 2.0 upgrade with my Spider V 240. Every preceding upgrade have been easy with no problems... Tried to upgarde with 2.0 firmware several times ..but recieved an error notice......AN ERROR HAS OCCURED. PLEASE TRY AGAIN. Then it gives me 3 suggestions in which try if it does not work. Why all previous ugrades were succesful and this one trashed? I am using Windows 7 64bit. Any suggestions?????? AAAARRRRHHHH!!!! Quote Link to comment Share on other sites More sharing options...
Strandflo Posted October 15, 2019 Share Posted October 15, 2019 I have the same problem with spider remote 2.0 on windows 10 (actual patch level) no other software installed The application crashes immediately after starting with the error: Faulting application name: Spider V Remote.exe, version: 2.0.0.0, time stamp: 0x5d3085bd Faulting module name: KERNELBASE.dll, version: 10.0.18362.267, time stamp: 0x91664cab .... Is there any workaround to get the app started???? Quote Link to comment Share on other sites More sharing options...
hyq1122 Posted October 18, 2019 Share Posted October 18, 2019 you only need install msvc run time dll all in one Quote Link to comment Share on other sites More sharing options...
spt182 Posted January 26, 2020 Share Posted January 26, 2020 buen día, yo tenia el mismo problema, instalaba spider v remote y al momento de abrirlo me mandaba un error que mencionaba que el software se detenia por un error y no daba opciones para solucionarlo, después instale los demás programas que necesitaba para escuela y el trabajo, posterior a esto decidí intentarlo de nuevo y el software funciono sin problemas, cabe decir que me marcaba los mismos errores como el de kernelbase.dll y otro más que no recuerdo, la lista de programas de programas que instale fue: netbeans, mikroc, proteus, matlab, guitar pro, c ++. Yo recomiendo instalar el kit de desarrollo de java, java, incluso net beans jajaja e intentarlo de nuevo les deseo suerte y saludos!! Quote Link to comment Share on other sites More sharing options...
luisma1972 Posted January 28, 2020 Share Posted January 28, 2020 having the same issue here, tried everything suggested and still doesn't work...... Just opened a Ticket, lets see what is tehe solution. Quote Link to comment Share on other sites More sharing options...
Samos12 Posted March 20, 2020 Share Posted March 20, 2020 Why does Line 6 not seem to care about the problems people are having here? It should not be up to the community to find their own solution. It's ridiculous... 1 Quote Link to comment Share on other sites More sharing options...
climb4fun Posted June 28, 2020 Share Posted June 28, 2020 Guys, I experienced the same issues mentioned. I tried all the suggested solutions. Nothing worked. I opened a ticket with Line6 support (Feb 2020). They made some deeper investigations together with me and confirmed it's a bug to be resolved on their side. Quote Link to comment Share on other sites More sharing options...
TomMelville85 Posted October 26, 2020 Share Posted October 26, 2020 Any updates to this problem? I just got a new laptop with Windows 10 and version 2.0.0 won't open at all. I worked fine on my previous Windows 10 laptop so I'm confused as to what the problem is. Quote Link to comment Share on other sites More sharing options...
jan_navara Posted January 30, 2021 Share Posted January 30, 2021 Discovered another hotfix that might help. Short story: Install Microsoft SQL Server 2016 LocalDB (download SQL Server Express 2016 at https://docs.microsoft.com/en-us/sql/database-engine/configure-windows/sql-server-express-localdb, launch the installer, choose Download Media, get the LocalDB installer) Long story: On my old laptop, installing the Microsoft Visual C++ 2015-2019 Redistributable helped (more or less, do not remember exactly), this didn't work for my new laptop though. Installed VS 2019 as a desperate attempt to fix the crash, and it succeeded. Verified that LocalDB is the key component that fixed the crash. Another odd observation is that the Spider V Remote installer already DOES include the Visual C++ Redistributable installer (Microsoft Visual C++ 2017 Redistributable (x86) - 14.11.25325) - click Show Details when the Spider V Remote installation is complete, locate the redist.exe file, you see? So it's quite a mystery why would we possibly need to install an additional Visual C++ Redistributable in some of the reported cases. 1 Quote Link to comment Share on other sites More sharing options...
bnillab Posted January 31, 2021 Share Posted January 31, 2021 I am wondering if it has to do with being a x86 program. We need an x64 version. Tired of this thing crashing all of the time. There are a ton of improvements that can be made!! We need alot of things in my opinion to help those of us who sank the money we did into gear that isnt working as advertised either. Like how i spend more time charging my original, and my 'replacement' gt10 dongle than i do getting to play with them on the 240hc mk1. Also kind of smiffed they released a mkii right after i got mine, stating the software/firmware upgrade would make it virtually the same.... then why make a mkii?? -frustrated customer! Quote Link to comment Share on other sites More sharing options...
Dishevel Posted February 2, 2021 Share Posted February 2, 2021 i just bought a spider v60 mkII i have no problems with the spider remote 2.0.0. Processor Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz 3.30 GHz Installed RAM 32.0 GB System type 64-bit operating system, x64-based processor Edition Windows 10 Pro Version 20H2 Installed on 19/07/2020 OS build 19042.782 Experience Windows Feature Experience Pack 120.2212.2020.0 i only know that windows home editions are not always complete with all drivers and DLL's Quote Link to comment Share on other sites More sharing options...
himynameisflo Posted February 3, 2021 Share Posted February 3, 2021 today i fixed it..... the solution is: Visual C++ 2013 Redistributable x64 its not in win 10 autoatically.....ive tried that several times....now it works.....Be sure you installed everything here: https://www.microsoft.com/en-us/download/details.aspx?id=40784 Quote Link to comment Share on other sites More sharing options...
transgrrl_rockn Posted March 14, 2021 Share Posted March 14, 2021 Im experiencing this issue also, on a laptop running Windows 7 and another cpu running windows 10. I tried updating c++ and most of the solutions presented in this thread besides the KERNELBASE.DLL thing. SQL Server Express wasn't compatible with my laptop, havent tried these solutions on the other cpu yet but i will after were done using it to watch TV. If i manage to get remote to work on either I will share here what happened, but so far I have tried it on both systems and it crashes shortly after opening the loading window. Id really like to get it working on both machines particularly the laptop because I plan on updating it to windows 10 anyways after I get paid, so I can run cubase on it and record as well as use the spider remote. I still need to buy the right cable to connect my android phone so this is my best option at the moment. I'm gonna try start a ticket if i cant get spider remote going tomorrow. Thanks for yall for contributing to this thread i hope we can all get it working! Quote Link to comment Share on other sites More sharing options...
01GT Posted March 30, 2021 Share Posted March 30, 2021 Fixed My Spider V Remote 2.00 Issue with Win 10 - Spider V - Line 6 Community Quote Link to comment Share on other sites More sharing options...
Bergcph Posted September 21, 2021 Share Posted September 21, 2021 well i had same problem lollipop all others dont open and shut down I FIX IT !!! i just unistal it and downlodad the first version and that worked then i upgraded it and are now useing v.2.0 Quote Link to comment Share on other sites More sharing options...
01GT Posted September 21, 2021 Share Posted September 21, 2021 14 hours ago, Bergcph said: well I had same problem lollipop all others don't open and shut down I FIX IT !!! i just uninstall it and downloaded the first version and that worked then I upgraded it and are now using v.2.0 Excellent. Hopefully everyone is beyond this issue now. What amp are you on? How you do like using Remote 2.0? Quote Link to comment Share on other sites More sharing options...
Bergcph Posted September 21, 2021 Share Posted September 21, 2021 im on v120 the best bye ever undtil now exept for my Fender Strat remote 2 is okey lfor me i use v2 and the one before that so its all good i mis some more custum tones in downloads :) if you all get the drift :) Quote Link to comment Share on other sites More sharing options...
