Sign in to follow this
guitarbloke1980
HX Stomp with Expression Pedal - Issues setting up
I’ve been trying to set up my Dunlop Volume X pedal with my HX Stomp as an expression pedal (I’m using a TRS cable).
However, then I push the pedal forward, all that happens is The Stomp says “EXP1 active”.  When I push it back, it activates EXP2.
No sound comes through at all, although I do get some hiss when I push it forward if there is a wah enabled on the current snapshot.
The pedal works fine on it’s own and works perfectly as a volume control.
There are some settings which I’ll admit I don’t really understand in the global section to do with polarity etc – but I have no idea what combination of settings I need to use to get this going.  I spent a while last night messing with various combinations and couldn’t get it working.
Any help would be hugely appreciated!
That means you have the expression pedal set to switch between expression 1 and 2. I don't have my Stomp by Mr right now, but it's a global setting.
Do you actually have an expression pedal with a footswitch? Because if it's just a regular expression pedal, no toe switch, try a TS cable first.
  • Thanks 1
Thanks Kilrahi,
The pedal doesn't have a toe switch, I'll give it a go tonight with a regular patch lead and see if it helps!
