wanderer80 Posted January 13, 2014 Share Posted January 13, 2014 Hi all, have two quick questions about the HD500X: 1. What do you find gives best results as far as System I/O goes? (I.e combo front etc) 2. The other night I was playing through some patches I had made and was adjusting channel volume and for some reason it keeps resetting the channel volume back to 100 even when I save at lower volume, any tips or tricks? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted January 13, 2014 Share Posted January 13, 2014 1. depends on what you are playing through... as that's the general purpose of that setting. use your ears and use the one that pleases you if you disagree with the "correct one" 2. sounds like it wasnt saving properly, i can't think of a scenario that would otherwise produce this result. Quote Link to comment Share on other sites More sharing options...
sonic Posted January 13, 2014 Share Posted January 13, 2014 Regarding question nr. 2 : is the channel volume controled by the expression pedal ? I noticed that it does not make a difference at what volume you set it as long it is controled by the expression pedals... Quote Link to comment Share on other sites More sharing options...
bvaladez74 Posted January 18, 2014 Share Posted January 18, 2014 Sonic is right. I'd bet that preset has the exp pedal turned on.....so if you manually adjust the volume and try to save it, it'll revert back to what the exp pedal is saved at. Quote Link to comment Share on other sites More sharing options...
