rafman21
Boot Failure. Entered Update Mode
While updating my Helix floor, it gave me "Boot Failure. Entered Update Mode" message on the pedal. After waiting half an hour it was still the same, so I canceled the process.
Upon Rebooting the HELIX same message showed up again and again. I tried changing usb cables and usb ports on my pc and it still did not work.
WHAT IS HAPPENING? I need my pedal back :( Help!
Reinstall HXEdit2.81, try holding FS6+12 at start, ...
...use the search button in this forum, this topic has been discussed many times ;)
Simple answer.
YOU DIDN’T READ THE INSTRUCTIONS!
Further more, when you post on this forum looking for assistance, it’s a great help to know what Computer and OS you are using. Although, I will guess - PC running Windows? This issue is usually associated with Windows Drivers.
You could try the suggestion, most helpfully supplied by “Peter”, in the post above.
In his comment, he mentions that this has been discussed many times, whereas I would state that it is more like hundreds of times.
Don’t panic - you will get your pedal back. ;-)
The answer is out there, all you need to do is look, but as you appear incapable of following instructions...
EDIT:
 This thread has over 120 replies and over 8,800 views. Took less than a minute to find!
Create an account
Register a new account
Sign in
Sign In Now
