guitarman19853 Posted August 27, 2019 Share Posted August 27, 2019 I'm considering purchasing an HX stomp and know that it can do some of the scenarios I want to use with it but I'm not sure about this one. I could figure this out myself in a couple seconds if I owned the pedal but I'm trying to decide if this is possibly before I make the purchase. TLDR: Can you run an amp/cab block on one side of a signal chain only and allow the other to go out unprocessed. The point would be to run a stereo rig with a real amp on one side and a modeled amp on the other. I know that I can do this if I run my entire pedalboard as it exists into the HX stomp acting just as Amps - then I could plug one pedalboard output into the Stomp and one into my amp. Easy. However, I really want the HX stomp to be fully integrated with my pedalboard. I want to run my signal chain as Guitar > Comp > Drive Pedals > HX Stomp > Stomp FX Loop Send > Stereo Delay > Stereo Reverb > Stomp FX Loop Return > Pedalboard out If I do this it lets me add additional effects before or after my delay/reverb or put my delay/reverb after the amp sims if I'm running direct. It also lets me make patches with no amps to run my pedalboard into real amps. However, there is a specific use where I want to run a single real amp and a modeled amp as the other side of the stereo chain. Can I do this within the editor/interface? I would need to put an amp block on the right side signal only. Thanks and sorry if this has been answered - Searching for "Stomp Amps Left Only" or Right Only doesn't give any useful search results... Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted August 29, 2019 Share Posted August 29, 2019 I believe you could do this so long as you split it into Path A and Path B. You would then need to pan the two channels hard left and right. I'd put the amp model on Path A but in reality it doesn't matter. In Path B you would need at least a dummy block (EQ, something - you could deactivate it if needed). Then at the very end of the chain rejoin them, but at the join point again pan hard left and right. I believe that would work. I haven't tested it though, but I did similar things with dual instruments and it worked so it seems like it would. Quote Link to comment Share on other sites More sharing options...
guitarman19853 Posted August 29, 2019 Author Share Posted August 29, 2019 6 hours ago, Kilrahi said: I believe you could do this so long as you split it into Path A and Path B. You would then need to pan the two channels hard left and right. I'd put the amp model on Path A but in reality it doesn't matter. In Path B you would need at least a dummy block (EQ, something - you could deactivate it if needed). Then at the very end of the chain rejoin them, but at the join point again pan hard left and right. I believe that would work. I haven't tested it though, but I did similar things with dual instruments and it worked so it seems like it would. Thanks! Someone else suggested I try it out in a trial of Helix Native in HX Stomp Compatibility mode and it seems to do what I want. Is there a performance or sound reason to put the amp block in path A? Because you're right, you need a dummy block in B. However if I put the Amp in B, no dummy is needed on A. Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted August 29, 2019 Share Posted August 29, 2019 9 hours ago, guitarman19853 said: Thanks! Someone else suggested I try it out in a trial of Helix Native in HX Stomp Compatibility mode and it seems to do what I want. Is there a performance or sound reason to put the amp block in path A? Because you're right, you need a dummy block in B. However if I put the Amp in B, no dummy is needed on A. Whoa . . . no I'm just a moron. I've always wanted the ability to do a blank Path B but it never occurred to me that you can do a blank Path A and in some cases that's preferable like this one where you're going to be doing both signals out of the main outs). Thanks for the idea! Quote Link to comment Share on other sites More sharing options...
