cclement
Frippertronics "looper" block
https://line6.ideascale.com/a/dtd/Frippertronics-loop-block/962141-23508
This is a bit of a selfish ask, but I figured I would try... maybe some others might dig it too.
I would love to see a "Frippertronics" style block in the Helix. Kind of like a looper... but not like the current looper. In my mind, this would be two independent delays, but with really long delay times - say 1 to  25 seconds each - even better is you could have the delay times listed in Bars.
Each delay would be fed from the same source, but fully independent. Each delay would also have a extremely long Feedback/Decay rate, so the repeats would go on for minutes if you wanted... but without ever going into oscillation like an analog delay.
There would also be a way to bypass the "input" going to the delays so you could add things to the loops, and then play over them. You could achieve this with "Tails On" kind of thing and standard bypassing the pedal.
Basically... I'm looking for something like the old Elottronix XL "Frippertonics Emulator" VST from way back - https://www.kvraudio.com/product/elottronix_xl_by_elogoxa - but inside the Helix.
