Sign in to follow this
Hollowman_d1
Helix Legacy to real models correspondence?
Guys, where can I find some all-in-one complete reference to understand what are the real models hidden under these tricky nick-names?
  • Distortion > Tube Drive
  • Distortion > Screamer
  • Distortion > Overdrive
  • Distortion > Classic Dist
  • Distortion > Heavy Dist
  • Distortion > Colordrive
  • Distortion > Buzz Saw
  • Distortion > Facial Fuzz
  • Distortion > Jumbo Fuzz
  • Distortion > Fuzz Pi
  • Distortion > Jet Fuzz
  • Distortion > Line 6 Drive
  • Distortion > Line 6 Distortion
  • Distortion > Sub Oct Fuzz
  • Distortion > Octave Fuzz
  • Dynamics > Tube Comp
  • Dynamics > Red Comp
  • Dynamics > Blue Comp
  • Dynamics > Blue Comp Treb
  • Dynamics > Vetta Comp
  • Dynamics > Vetta Juice
  • Dynamics > Boost Comp
  • Modulation > Pattern Tremolo
  • Modulation > Panner
  • Modulation > Bias Tremolo
  • Modulation > Opto Tremolo
  • Modulation > Script Phase
  • Modulation > Panned Phaser
  • Modulation > Barberpole
  • Modulation > Dual Phaser
  • Modulation > U-Vibe
  • Modulation > Phaser
  • Modulation > Pitch Vibrato
  • Modulation > Dimension
  • Modulation > Analog Chorus
  • Modulation > Tri Chorus
  • Modulation > Analog Flanger
  • Modulation > Jet Flanger
  • Modulation > AC Flanger
  • Modulation > 80A Flanger
  • Modulation > Frequency Shift
  • Modulation > Ring Modulator
  • Modulation > Rotary Drum
  • Modulation > Rotary Drm/Horn
  • Delay > Ping Pong
  • Delay > Dynamic
  • Delay > Stereo
  • Delay > Digital
  • Delay > Dig w/ Mod
  • Delay > Reverse
  • Delay > Lo Res
  • Delay > Tube Echo
  • Delay > Tape Echo
  • Delay > Sweep Echo
  • Delay > Echo Platter
  • Delay > Analog Echo
  • Delay > Analog w/ Mod
  • Delay > Auto-Volume Echo
  • Delay > Multi-Head
  • Pitch/Synth > Bass Octaver
  • Pitch/Synth > Smart Harmony
  • Pitch/Synth > Octi Synth
  • Pitch/Synth > Synth O Matic
  • Pitch/Synth > Attack Synth
  • Pitch/Synth > Synth String
  • Pitch/Synth > Growler
  • Filter > Voice Box
  • Filter > V Tron
  • Filter > Q Filter
  • Filter > Seeker
  • Filter > Obi Wah
  • Filter > Tron Up
  • Filter > Tron Down
  • Filter > Throbber
  • Filter > Slow Filter
  • Filter > Spin Cycle
  • Filter > Comet Trails
foxmister, thanks. I'm aware about this link. Just, I meant the Legacy models that were initialy developed for other Line 6 devices. All these models are in a separate directory called "Legacy" in the Helix.
Well, these are named “Legacy” models because they are the same as the effects that shipped in the old “M” series FX boxes and the ones used in the POD500X. If you find the model names a little esoteric, you can check what they are based on, along with a description of the ones specifically created by Line 6, in the Manuals for either the POD or M series stuff.
Here ya go:
https://uk.line6.com/data/6/0a060b316ac34f0593f9471cf/application/pdf/M13/M9/M5 Model Gallery - English ( Rev D ).pdf
Have fun
Note: You will realise that a lot of these models have better high quality HX versions already in the Helix, but not all were updated - therefore you have Legacy versions.
I reference the HD500 Model Gallery PDF that I have downloaded to my computer.... but that M series gallery posted by datacommando above would be more appropriate since the HD contains the amp models that are irrelevant.
  • Thanks 1
  • Delay > Ping Pong
  • Delay > Dynamic
  • Delay > Stereo
  • Delay > Digital
  • Delay > Reverse
  • Delay > Lo Res
  • Delay > Tube Echo
  • Delay > Tape Echo
  • Filter > V Tron
  • Filter > Q Filter
  • Filter > Seeker
  • Filter > Obi Wah
  • Filter > Tron Up
  • Filter > Throbber
Another option is to download the HX Stomp manual. While you don't have the Stomp, the manual has most of the Helix's effects updated within it, including the legacy effects. I printed off those specific pages.
