Sign in to follow this
Mr_Powers
Need Help: 4 Cable Method On Pod Pro Rack Mount
Hello All!
Let me start by saying that I'm a total n00b connecting effects pedals let alone using the 4 cable method.
I have the LINE 6 POD PRO RACKMOUNT EFFECTS PROCESSOR (link to pod: http://medias.audiofanzine.com/images/normal/line-6-pod-series-pod-pro-329756.jpg) and would
like to connect it to my Peavey 5150 II amp. Me and my buddy tried the 4 cable method with the help from various suggestions we found on the web. We got really close to making it work, but when we
would turn off the effects loop to cancel the effect from the POD we were still able to hear the amp model effect from the POD.
So here are some questions:
1 - If possible, how do I properly execute the 4 cable set up to my equipment. (Reverse side picture of POD & amp https://www.dropbox.com/s/5ebw0vrxilnmwqy/Photo%20Dec%2016%2C%208%2042%2046%20PM.jpg)
2 - is it possible to only get the true amp sound while hooked up to the POD?
3 - is it possible to use my amp's clean sound and use the effect from the POD, like the delay, flanger, chorus...etc., this would also mean bypassing the AMP MODELS settings from POD.
Any suggestions would be greatly appreciated. Thank you!
The correct connection setup is:
Guitar > Pod Guitar Input (cable 1)
Pod Send > Amp Guitar Input (Cable 2)
Amp Send > Pod Return (Cable 3)
Pod Left 1/4 Output > Amp Return (Cable 4)
To get your amp sound into your preset, make sure to add the FX loop block in the patch. You will have to play with the fx loop levels to get the proper sound
You can use clean or dirty sounds from the amp (same as above), but you will have to manually switch channels on the amp with it's footswitch, you can't do it from the Pod (unless the Peavey has midi control)
Thank you so much dabagchee, I'll give that a try.
Although I don't quite understand when you said "make sure to add the FX loop block in the patch".
Could you please explain it in laymen's terms? I apologize for my lack of knowledge.
Thanks again!
The FX Loop can be added, or not, to any preset just like any FX model. It can be positioned anywhere in the signal chain, wherever you wish.
  • Upvote 2
What silverhead said. Basically since your amp's preamp is now in the Pod FX Loop, the FX Loop block will represent your amp in your patch. If the FX loop is there and turned on, you'll hear your natural amp sound coming through (plus anything you have setup in the Pod) - if it's not enabled or not in your patch at all then you'll only hear sounds from the Pod.
You guys have been awesome.
I haven't had a chance to work on it, but I'll make sure to give you all an update once I do.
Thanks again!
I just found this while looking for information on the Pod Pro's FX loop and...
Guys, dbagchee, silverhead... the Pod Pro doesn't have any FX block. It has a stereo FX loop, but its position is fixed, and certainly, not configurable or represented in any way on any of the editors (Sound Diver, L6 Edit, Midiquest) or the unit's own interface.
The Pod Pro is not the Pod HD Pro. The topic is misplaced.
There's so many Pod's specifics become very important.
Taking a look at the linked picture in the original post would have done the trick though  :D
