emagli Posted September 6, 2019 Share Posted September 6, 2019 Hi all, I have been using a Digitech Drop as first pedal before my Helix LT for a while now. It works ok, but I can indeed hear a slight tone loss if I drop by 1 step or more -- my crunch tone (based on plexi) is less punchy and lacks high end. We have a dense mix in the band (2 guitars + keyboards), so most of the time this is not very noticeable. However, this can be clearly heard when I play chords while all other instruments are silent (think of the beginning of Bryan Adam's "It's only love"). Do you have any tips about how to eq my patches in order to adjust the tone to compensate for the Drop? (I usually use a Minotaur + low gain plexi for base crunch tone, then a combination of OCD pre-amp slight boost, increased amp gain, and post-cab Cali eq for low-cut and mid- and level boost for leads). Thanks! Quote Link to comment Share on other sites More sharing options...
Heavyville Posted September 6, 2019 Share Posted September 6, 2019 the lower you drop the less gain you should use. your tone will sponge or loosen, its the law of how that crap works. you wanna punch through, lower your gain and boost the mids. Do it while your at rehearsal. Quote Link to comment Share on other sites More sharing options...
