HX Stomp and HX Effects should swap platforms
randywillcox
I can't help but feel Line 6 missed out by not making the HX Stomp the size of the HX Effects and vice versa.
The Stomp has amps and cabs with limited blocks. So if you want an amp and cab, you're left with 4 blocks. The Effects has the ability to Use a lot more blocks and load IRs, but no amps and cabs. So you have more switches and fx...but need to provide amps.
It seems you'd want the extra blocks and buttons on the item you use as the all in one.
The Stomp is being put on pedal boards as an effect pedal when it's supposed to be a baby Helix.
I feel like they should make a stop the size of the HX Effects with all the blocks AND THE ROUTING. You can still stick it in a gig bag. If your gig bag won't hold the HX Effects size pedal, you need a better bag.
It's not going to kill the sales of the full size Helix. People that want that will buy it. I just sold mine because I'm using the Kemper Stage for main gigs now. But for a small unit to throw in my bag for jams and rehearsals, I got the Stomp, and it sounds great, but it's so limited I'm tempted to sell it and go with an Atomic Amplifire 6. I dunno. I'm just hoping Line 6 considers this. I think the unit would be killer if it were basically an HX Effects with the amps and cabs added to it. Helix Mini, as it were.
