vinny_x3 Posted September 10, 2019 Share Posted September 10, 2019 (Hello ! It's impossible to install the 2.81 version on my HX Effects. The current version is the 2.80.1, but when I try to install the last version, the process begin, and next, all the screens of the HX are empty, Windows 10 reports me that a device is unplugged (with a bip), and the updater gives an error. I tried with an other ubs cable, directly on my pc (no hub), and this is the first time I have this issue. Somebody has had this problem ? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted September 10, 2019 Share Posted September 10, 2019 5 hours ago, vinny_x3 said: Hello ! It's impossible to install the 2.81 version on my HX Effects. The current version is the 2.80.1, but when I try to install the last version, the process begin, and next, all the screens of the HX are empty, Windows 10 reports me that a device is unplugged (with a bip), and the updater gives an error. I tried with an other ubs cable, directly on my pc (no hub), and this is the first time I have this issue. Somebody has had this problem ? Thanks in advance. Did you carefully follow the firmware update instructions with the release of 2.81? There really are only a few core steps in the following order: 1. If you care about your presets, back them up first. 2. Update HX Edit to 2.81 FIRST. 3. Once HX Edit has been updated, launch the Line 6 Updater, login, and update your HX Edit. I bolded the step I would verify you've done first. Quote Link to comment Share on other sites More sharing options...
vinny_x3 Posted September 11, 2019 Author Share Posted September 11, 2019 Thanks Kilrahi for your answer. I updated without problem the 2.80 and 2.80.1 versions before this one. I always follow scrupulously the instructions, that's why I was surprised by this problem. But I tried with another computer, and all worked fine. Apparently, the usual PC was on strike... :-) I will see with the next upgrade. Anyway, thanks a lot for your help. 1 Quote Link to comment Share on other sites More sharing options...
