sami568 Posted September 10, 2019 Share Posted September 10, 2019 Can I assign one expression pedal controller to amp volume and another expression pedal controller to chorus depth without using up blocks? Or does each controller use up one of the 6 blocks? Thanks for helping a newbie! Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted September 10, 2019 Share Posted September 10, 2019 3 minutes ago, sami568 said: Can I assign one expression pedal controller to amp volume and another expression pedal controller to chorus depth without using up blocks? Or does each controller use up one of the 6 blocks? Thanks for helping a newbie! You're referring to the HX Stomp? I am a Stomp user. I love the thing. No, controller assignments do not use up blocks. In fact, that's one of the biggest strengths of the Stomp to handling its six block limit, you can do FAR more controller assignments than you could in a typical rig. There is a limit to the number of controller assignments you can have. I'd be shocked if you hit it though. I've never come close. Quote Link to comment Share on other sites More sharing options...
fenderbenderlax Posted September 10, 2019 Share Posted September 10, 2019 Nope...u can assign the parameter to an expression pedal but no need for a block... Quote Link to comment Share on other sites More sharing options...
