chrispilpa Posted September 12, 2019 Share Posted September 12, 2019 Hi Guys, I am new to Cubase LE that I got from my Spider V. I have been trying to use my Amp as the audio interface for recording in Cubase. The instruction says that I need to install the Line 6 driver. But it causes my Windows 10 to crash. It means there other ASIO drivers in my PC that conflicts with Line 6 and I am not sure how to fix this. Does anyone have this similar problem? Thank you Quote Link to comment Share on other sites More sharing options...
Rayk86ss Posted September 13, 2019 Share Posted September 13, 2019 My HP windows 10 laptop has locked up many times while playing audio, but not to a total blue screen level of frozen. The problem is the Windows Audio Device Graph Isolation bug. The only solution I've found is to go into task manager and delete Windows Audio Device Graph Isolation. Audio plays normally after that. Quote Link to comment Share on other sites More sharing options...
joestides Posted September 14, 2019 Share Posted September 14, 2019 be sure you install drivers with the amp unplugged from your computer. Quote Link to comment Share on other sites More sharing options...
Kobradelta1000 Posted January 13, 2020 Share Posted January 13, 2020 Hello!, Got my new V20 Mkii today, installed the latest driver 1.91- as soon as i connect it to my pc a bluescreen happens.... Win 10 home 64 Quote Link to comment Share on other sites More sharing options...
indridious Posted March 2, 2020 Share Posted March 2, 2020 i downloaded the latest drivers and as soon as i plug the amp into my pc i get a bluescreen. Quote Link to comment Share on other sites More sharing options...
Kobradelta1000 Posted March 2, 2020 Share Posted March 2, 2020 Hi, My problem was the RAM CACHE from Asus and or the Logitech GHub - Software If you have any of these, uninstall them - in my case it worked! Cheers Quote Link to comment Share on other sites More sharing options...
edata2008 Posted May 7, 2020 Share Posted May 7, 2020 I have the same problem with my Dell XPS 15 7590 with Spider V 120. Uninstalling the Logitech Hub software did help. This should not have incompatibility issue with any software or hardware @Kobradelta1000 thanks for the advice. That helps a lot. Quote Link to comment Share on other sites More sharing options...
