mikeharris7
HX Stomp Buzzing Loudly only when USB connected
Hi all - I have a strange issue going on with my Stomp. Whenever I have it plugged into the computer with the USB cord I get loud buzzing. Even more weird, the tone of the buzz will alter as I close or open programs or web pages. This is most problematic when editing or creating presets. I made sure the Stomp is not assigned to be my audio interface for the computer. I'm running Windows 10 on a Dell laptop that is a little older now.
Is there a reason you aren't using the Stomp as your main audio interface?  That's exactly what it's designed to be.
Another thing to always check is to make sure the USB cable isn't borked.
If it's the noise I'm thinking of, it's a ground loop. Usually a ground loop is 60 cycles, but the USB involved type is kind of a high frequency whine, like a giant mosquito. I've had it in multiple configurations (complicated studio setup). Most recently I was running the computer's audio out to my Scarlett mixer/AI. Though my Helix wasn't the AI, I was getting the noise. I put a cheap Pyle "Hum Destroyer" that I got on Amazon for a few bucks between the computers audio out and the Scarlett input, and that solved the problem.
What else is hooked up to the Stomp?
this is definitely a ground loop issue.
start unplugging other things to see if it goes away. Try other plug sockets.
you can try and chase it down or do what @rd2rk mention with a hum destroyer type device.
good luck.
USB earth hum. It exists. It goes away when plugged into a laptop running on battery power.
It sounds REAL bad with my Stomp through my Fender amp, though I just ignore it for the most part
I also have buzzing when my Stomp is plugged into my laptop AND I’ve started my DAW (I don’t use the Stomp as my audio interface). For me, it’s a simple fix....just unplug it when using my DAW, but it’s certainly interesting.
I have a Steinberg as my audio interface. I'm not opposed to using the Stomp just mentioned that I turned that off.
good luck.
It literally ONLY happens when I plug it into the laptop. It doesn't matter what else is plugged into the Stomp so far.
Understood, but its important to understand what else is plugged in to your "signal".
I also get a ground loop issue when USB is connected and i'm also routing a signal to a physical amp at the same time.   The USB is the culprit that's causing it for me.
so when i'm adjusting my physical amp i cannot have the USB connected.
i can resolve it with a hum eliminator device, but unplugging it is way cheaper.
I have the exact same problem - used a hum buster and it seems to have fixed it. Annoying problem but I'm glad I happened to have a hum buster around
I had this problem for some time. It's a ground loop issue that the HX Stomp is wickedly clever at finding. I tried EVERYTHING. But one day I realized there was one connection I overlooked...
My computer monitor was connected  to my computer's HDMI output. When I disconnected the HDMI cable,  the hum disappeared. So I just use my VGA output on my computer instead. Small price to pay. That hum was beyond annoying. I did try plugging the power of my monitor into another circuit but that didn't help so I just left it. Just Happy it's gone.
G
Sorry I do quote myself :P
On 3/28/2021 at 11:37 PM, PierM said:
These noise problems are rarely caused by USB cables, but instead it's typically interferences produced by devices connected to the PC/Laptop, passing through. Try unplugging everything from that PC, apart the Helix, and see if does help.
In my experience, many times are PC monitors using HDMI ports, but can be virtually anything using a wall socket.
