Sign in to follow this
tonee132
podhd500x hook up
Yeah, you can't go wrong with G, Em, D & C. :-)
  • Haha 2
Yes of course it's good. I'm using it live and at home. Just check if your amp got serial or parallel fx loop. If it's parallel you can't do it :D . (If you don't know if serial or not, just put a 1/4" cable into the return  jack and try to play. If the amp is quiet it's serial. ) Then you have to check the settings on your pod with the switches on the back and near your expression pedal.
