Question About Using The Pod Hd With A Daw
mihnea912
Good day ,
The title is not really the most appropriate ...but I didn't know how to call my problem , so allow me to explain .
  I connect my POD HD to the PC via USB and use it as an external sound card , I use it with my DAW to record . I set up my effects on the POD HD and my signal , with effects and all , is fed into the DAW .
  To the before-mentioned signal , I add effects directly from the DAW and I want to hear the sound in REAL TIME as I am playing . But when I want to hear it in real time , I hear the signal doubled : The RAW SIGNAL that is fed into the DAW from my POD HD and the RAW SIGNAL + DAW EFFECTS both come back through my headphones or speakers.
  Is there a way to mute this RAW SIGNAL , so I could hear only the signal that comes back from the DAW ?
You don't want to mute the raw signal.  You want it the other way around.  Mute the guitar track you're recording at the daw.  The latency in listening to the guitar track from the daw will throw it out of time with the rest of your tracks, as well as throw off your playing timing.
I'm not recording , I want to listen in real time , to monitor it... Hmm . Lets say I have a CLEAN signal coming from the POD into the DAW and I have an amplifier on a VST in the DAW ... I want to click the "Monitor" button , and I hear the CLEAN + the signal with the added amplifier into the headphones. I want to not hear that clean signal .
I know I hear the clean signal doubled because I have the headphones connected into the POD ( the pod producing the signal directly in to the headphones ) and the POD used as an external sound card . My question is , how to mute the sound of the pod heard in the headphones.
Wait now...as long as you don't use any DAW FX that introduce latency, you should be able to get sub 10ms latency through a DAW.  The manual shows a buffer of 256 samples in the PC USB driver, and says it can be set lower.  I set my Prosonus Firebox to 6ms (256 buffer samples) and it never throws me off.   There is also a ~1ms added delay for every foot you are from your monitors.  You should record at 24bit 48kHz SR -- as it's the Pod HD native rate.  You can cut the latency as much in half by recording at 96kHz, but you won't gain any signal resolution and the total CPU use will double.  At other SR settings, the real time USB driver SR converter may add latency.  Real time SR conversion is inferior and could possibly cause a midi timing sync issue that builds up over time -- as was the case with the old SBLive soundcards.
As Gunpointmetal pointed out, go to line 6 devices and on the monitoring tab lower the slider all the way to the left. Now set the buffer to the lowest possible and you will get latencies of somewhere between 10 -15ms. It can be useable. Now remember if your not using your daw and the USB is connected, there will be no sound coming out of the POD unless you go back again in Line 6 devices to move the monitor slider to the right, or if you fire up your DAW and active the monitor on one of the tracks.
Working with the Monitor and Send sliders in the ASIO driver interface COULD be a possible solution, but in my experience, most users find the latency to be objectionable, UNLESS, they have a fairly powerful computer, a DAW that manages memory and processor well, and are not overly sensitive to the delay.  I've seen some very time sensitive users on this forum complain about under 5 ms latency.
Why try to find work arounds, when simply muting the track that the guitar is in, and listening to the guitar through the HD, which is basically "tone direct", works great?
