Sign in to follow this
sami568
Does the Helix Floor have more adjustments than HXstomp?
I noticed that the presenter of this video had a presence control for his Brit JM45 model.  On my Stomp I only have bass mid and treble controls for tone.  Are there more parameters offered on the floor Helix?  Or is it a firmware difference?   Thanks!
They're identical.
I don't have the HX Stomp with me so I can't check, but are you pressing the "page over" button to see ALL of the amp settings?  Most of the amps have quite a few more options than what you're mentioning above. You ought to be able to see cab settings too by paging over.
Interesting. Yeah, if you're using HX Edit then you should see it all there.
They are identical though. So if it was present there the only other option would be if they removed it from all of them.
Are you sure you're using the exact same one he is? He's using the bright model. Are you using the normal one that is just above it?
I believe all the amp models have a presence control. But the comment above is correct, all the parameters for the amps, effects, etc. are identical on the Helix and the HX Stomp.
I wouldn't be surprised if you're actually using the Pre version of the amp and not the full amp block.
Mystery solved - I was using the Preamp version of this model.  Since presence comes in on the power amp side it is only there in the AMP model, not the PREAMP model.  Thanks for your help!
