rudomat
run hx in 4CM while post fx path is in killdry mode?
question: can i run the hx stomp in 4CM and have only the post fx path (after the preamp) for delay, reverb, etc, in killdry mode...?
or would the killdry mode be global and then also affect the whole unit...? or can killdry be done for each fx block extra...?
thanks
There is no kill dry mode. You can set the Mix parameter of an individual effect to 100, and that will be 100% wet, but that will only work if you're using that one effect. If you put a reverb, for instance, after a delay for which you have the Mix set to 100, the reverb would only be affecting the repeats.
Create an account
Register a new account
Sign in
Sign In Now
