Moon_Raven Posted September 23, 2019 Share Posted September 23, 2019 Hello, I am using Line6 Helix as an audio interface for my computer. I am trying to change the buffer size from my DAW(Ableton live), but when I open the ASIO Helix driver, I see no such options. Is it possible to change buffer size from the default 128 samples? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 23, 2019 Share Posted September 23, 2019 In PREFERENCES - AUDIO click HARDWARE SETUP. There's a Slider titled ASIO BUFFER and the range is EXTRA SMALL to EXTRA LARGE. It's stupid, but it is what it is. EXTRA SMALL is 64. Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 23, 2019 Share Posted September 23, 2019 If you're trying to use the Helix in a direct monitoring scenario, you probably won't like the results. Line 6 doesn't make low-latency drivers for the Helix line. Quote Link to comment Share on other sites More sharing options...
