Sign in to follow this
JimRad
Tilt Stand for Yamaha DXR10 (3D print)
The Yamaha DXR10 mkII is a great, great sounding unit with the Helix.
I wanted the sound projected upwards while standing up to preserve the wide horisontal coverage so I designed and made a 3D printed tilt stand that fits into the speaker stand holes. It's a nice and small thing that fits in the junk-bag to avoid lugging a big and ugly speaker stand.
You can download the STL file for 3D printing here: Thingiverse JimR Tilt Stand
Edit: I should have said this right away: I am not offering to manufacture these, it takes 9 hours to print and is not really worth my time for the small amount of money people want to pay for 3D printed parts.
JimR
  • Like 2
  • Thanks 1
@JimRadWow! Jim these are awesome!! I don't have a 3D Printer, but thanks for posting this. Any chance I can send you a few dollars to have you send me a couple in Black? I have 2 DXR10 that these would work great with. PM me if you're so inclined. Otherwise, I'll try and see about getting them printed locally.
sorry mate, grab the file and find someone local to do the 3D print.
br
Jim
Excellent idea and execution!!!  Chances are this design would work for most powered speakers.  You might spend some time getting a patent then licensing the idea to one of the many manufacturers of stage gear.  That might be worth your time.
Jim,
it is hard to overstate how useful this stand can possibly be. I gigged a couple of nights ago; trying to put my DXR10 on a regular amp stand to decouple it from the floor, I had a lot of trouble because the knobs and XLR cable on the back of the DXR10 would constantly end up against the metal pipes of my stand, at the risk of breakage. Your design looks like a brilliant solution to this. Thanks for sharing! And agreed, a great sounding unit for Helix.
@JimRad One of the fabrication sites shows: 17% Infill and, > 0.2mm Layer Thickness fabrication parameters. Are these specs in your file? If so, that makes things straightforward. What material did you use? PAL? ABS? Other?
That took 9 hours? What is your printing speed, 20mm/s? I print at 80mm/s and feel like that would be a 3 hour print if that 17% infill is to be believed. Now if you did it at 90% infill maybe... highly modified Maker Select + here.
I'm using an Ultimaker 2+ and this is one of my first prints using PETG (Cura calls it CEP), I think I used 40 mm/s but I am working on getting it faster, I think I'm up to 60 mm/s now. I had major issues getting it to stick to the build plate at first but a few coats with PVA glue and slow brim speed made a difference (and 80 degrees build plate)
Jim
Create an account
Register a new account
Sign in
Sign In Now
