Variax on mobile devices / iPadOS
I’ve started using the iPad as a simpler, more mobile setup for doing my thing, and ... it’s really nice. I’m a little unclear, however, if the Variax is best used via by routing through POD or if it can go “directly” into the mobile device.
I’m currently using Cubasis as my AU host, and I was curious if just using the USB interface would work as another audio interface on iOS, and any setup suggestions.
You can connect your Variax to any audio interface using its 1/4 analog output. Of course you will be sending the raw signal of the selected Variax model. There will be no signal processing such as your POD provides; you will need to do that in some other fashion.
