HX Stomp - noise and tone issues
Rob-Thunder
I just received my HX stomp yesterday, and have been messing about with it, trying to work out what it can do. But I seem to have a problem.
I have similar problems in other settings, but for simplicity I will focus on the following situation.
In global settings output level is set to instruments.
My guitar is plugged into input L/mono
The stomp is plugged into my amp (output from the Stomp: L/mono)
I am using an FX preset (so effects pedals only)
I have switched all the effects off - so I should just be getting the sound of the amp
I have also set footswitch 3 so that, when clicked, it by-passes the Stomp completely (comes up with the message: Analog bypass)
So then I tried the following three things:
1) unplugged the HX stomp and just plugged the guitar straight into my amp
2) going through the HX stomp, in an FX preset, but with all pedals off
3) click footswitch 3 to get "analog bypass"
I would expect all three of these to essentially sound the same. However they don't.
1) sounds good - as I'd expect it to.
2) sounds bad. It introduces background noise, and the volume decreases significantly, and all the good tone is basically lost
3) brings back the volume and good tone, but still has the background noise.
Is this normal?
Have I done something wrong. Do I need to change some settings? Or does it seem that I have a faulty one?
Any help appreciated.
Thanks
Rob
Hmm, I think I may have solved the problem.
I am not sure what the problem was, but I did a reset - holding all three switches down while turning it on - and I think that seems to have made it better.
I think I might need to play with it a bit more to check, but I think its good now - certainly better.
No idea what I had done wrong before though.
Actually,  I don't think the reset had anything to do with it. The problem (which came back) is that the Stomp seems to get noisy when I plug it into the computer, via the USB.
I guess it isn't the end of the world - as I can always disconnect it before playing - but a bit of an inconvenience.
Has anyone else experienced this? Is it normal, or an indication that something is wrong?
Thanks
My guess is that you're experiencing a ground loop - electrical interference between your laptop computer and your HX Stomp. Try unplugging your laptop and running it on battery. If the noise disappears then this is the problem. There are solutions available but we don't need to go there until/unless you confirm the issue with the above test.
  • Thanks 1
I suspect this is probably right. The computer I was using is a desktop, rather than a laptop - so can't run it off the battery,
However, I have just tried the Stomp with my lap top - and in a different room - and I don't have the noise issue (and the laptop is actually plugged in too).
If the solution is super simple, it would be good to know. Otherwise, I confess I probably wouldn't get round to solving it. I guess my priority was to check I didn't have a faulty Stomp. And if I do want to have the Stomp connected to the computer, while playing, I guess I can now use the laptop.
Thanks
Rob
One solution is to purchase a product called a hum eliminator. A google search will give you many options.
A simpler solution might be, as you've already discovered, to experiment with different electrical outlets. For instance, if your current setup has both your computer and your Helix connected to the same power bar you might try plugging each directly into two different electrical outlets.
  • 1 year later...
Hey Helixers!
Got my brand new HX stompbox today and hooked it up!! Some great sounds there.
Aimed to put it onto my pedalboard in the effects chain thusly:
Guitar - Wah pedal - Eventide H9 - Line6 HX - KoT - Klon - Strymon Flint - MXR Carbon copy - Marshall amp.
The Strymon and MXR and Klon were NOT happy! Horrendous noise. I discovered the culprits by isolating pedals one by one.
The noise was present even when the digital stuff was in bypass mode.
Testing the analog pedals one-by-one confirmed that they were all ok individually.
Eventually i've arrived at Guitar -Wah- H9 -HX-KoT-amp. Not completely noiseless but certainly a vast improvement and useable.
I like to have my analog kit with its simplicity and ease of use.
Advice and feedback greatly appreciated.
I am having the same problem of so much background noise using the HX Stomp that it is unusable for recording.  I am using a Dell Windows 10 laptop with the HX Stomp attached via a USB cord.  I am using a Focusrite Scarlett instrument input and am using Ableton Live 10.  I purchased a noise reduction patch bay and that did not help. I've tried every iteration of connection from line out, headphones jack, and sends.  I am not having this issue with any other piece of gear so I don't think it is my outlets.  I have power filter surge protectors.  Anybody have a suggestion?
  • 1 year later...
Wow, you saved me a lot of time and frustration with this comment! I didn't even think about the USB :-/ I unplugged it, and problem solved. It's (almost) completely quiet now. Thank you!!!
Rich
