bigschnoz Posted May 19, 2013 Share Posted May 19, 2013 Hi folks, I have recently purchased an HD500 and DT25. I have flashed the HD500 no problem but I am getting the common errors with the DT25 when attempting to flash using usb-midi cable. I have tried all the suggested tricks but it does look like I need to buy a decent midi controller. I was already on the lookout for a simple midi keyboard controller to enable me to record some basic synth / percussion etc on cubase. I am looking at a :- Behringer UMX250 U-Control 25 Key USB/MIDI Controller Keyboard with USB/Audio Interface Anyone know if this will enable me to flash the DT25 or is it the wrong sort of device for that? Cheers in advance, Steve (PS any tips on a better small midi keyboard controller around the £100 mark will be gratefully received) Quote Link to comment Share on other sites More sharing options...
mribanezmetal Posted May 19, 2013 Share Posted May 19, 2013 M Audio Midi Uno 1x1 should work as a simple USB to Midi in/out cable. http://www.m-audio.com/products/en_us/Uno.html For updates with my DT50 I've had succes with the Rig Kontrol board by Native Instruments which is part of Guitar Rig if you where thinking of a good VST http://www.native-instruments.com/en/products/komplete/guitar/guitar-rig-5-pro/ Also the M Audio Key Rig 49 is a pretty cheap controller or try looking at the Samson Graphite series that come bundles with Komplete Elements by N.I http://www.samsontech.com/samson/products/usb-midi/ Cheers Quote Link to comment Share on other sites More sharing options...
bigschnoz Posted May 23, 2013 Author Share Posted May 23, 2013 Cheers, I will take a look at the usb - midi and their keyboard controller range. Still not sure if I can flash the DT25 via a keyboard controller. Quote Link to comment Share on other sites More sharing options...
mribanezmetal Posted May 24, 2013 Share Posted May 24, 2013 Yeah you could definately flash with the first two but not sure about the controller. Good luck! Quote Link to comment Share on other sites More sharing options...
oldgitguy Posted June 5, 2013 Share Posted June 5, 2013 I can say that using the m-audio uno was as simple as it gets. Using an iMac, plugged in the usb uno, hooked midi side to the Dt25, (it even tells you which cable goes to what on the cable itself), launch Monkey, pick your Dt25 amp, then choose update selection.worked first time no issues. I would definitely recommend the uno! Quote Link to comment Share on other sites More sharing options...
bigschnoz Posted July 6, 2013 Author Share Posted July 6, 2013 Still struggling to update using the uno, what power state did you have the amp in for update? Quote Link to comment Share on other sites More sharing options...
mribanezmetal Posted July 8, 2013 Share Posted July 8, 2013 Had it in Standby. Describe your issue? Quote Link to comment Share on other sites More sharing options...
