Sign in to follow this
borgis
Snapshots change audible gap
Hi
Quick question.
Isn't using snapshots supposed to change settings without a gap in audio output?
So so if you are in the middle of a song and have time based effects like a delay with repeats and a lush reverb, as long as trails are turn on, changing the snapshot will be seamless.
If you have a guitar with sustain for miles, and you let that last amazing chord ring out at the end of the song ring out, and change the "patch",  you are going to hear a short interruption of that beautiful chord.  Bummer.   But if you are using your snapshots instead, you can select the desired snapshot and the new effects will take effect, but no gap.  But you might hear your fabulous distortion change to clean all of a sudden which might not be what you want.
Im going from cleanish to heavy , im automating mic distance and early reflection and drive.
Changing the mic distance might introduce an audible gap. That's essentially the same as changing an IR, so I could see why that could cause a bump. Don't do that... ;-)
Create an account
Register a new account
Sign in
Sign In Now
