Helix Connected to 2 Separate Power Cab Plus 1x12 - Separate Chain / Path
Thuggies
Can I run a separate cab configurations to each speaker?
I can an XLR going out to each.
Let me know if you have any ideas or if anyone has done this yet.
Thanks all!!
Jeff
Hi Waymda - Thanks for the response!
This is sans a PC connection, but I could use Edit to configure.
Basically, this is the setup:
Helix > PowerCab Plus 1x12
Within the same patch, I'm just wondering if I can have separate Amp/Cab combos go to each separate 1x12?
are you asking about having diffeent speaker settings on each of the two PC+s...then Yes.
If you are asking if you can have two outputs (L&R?) from the helix withdifferent  Cabs in those chains and the PC+s running in FRFR mode...Yes.
You could even run two completely seprate chains from one input with diffrent FX and aAmps and cabs etc on each, going to the two PC+s in FRFR mode...
or you could save the bock and run no cabs in the helix as noted above...
Think when waymda said 'PC' he was referring to Powercab, not Personal Computer
I have 2 PC Plus cabs I use the line 6 Link cable to the first cab and another link cable between the 2 PC plus cabs...... I use the speaker simulations in the power cab
and you can set them to be the same or you can set them to be different speaker types for each preset or each snapshot......
  • 1 year later...
