Ed_Saxman
ROLAND FC-300 SYSEX mode for HX STOMP
Wouldn't it be wonderful if our HX Stomp had a dedicated professional, gig worthy, Plug & Play controller, where you don't have to program anything?
What if it could also work with batteries, and... wirelessly?
Better with a large touch screen as H.U.D?
ROLAND FC-300 SYSEX MODE For HX STOMP
https://gum.co/AnHuek
Version 1.0 (5 Presets)
Preset Mode:
Stomp Mode:
iPad Main view
Looper controls
This is a MIDI Layout Made to work with MIDI Designer Pro 2 (sold separately).
Allows to use a Roland FC-300 MIDI pedalboard with the Line 6 HX STOMP, using SYSEX messages to control all the onboard LEDs, expression pedals and footswitches.
Plug & Play. No config needed.
Partially Wireless!! Plug your FC-300+iPad together, then control your HX Stomp Wirelessly!
Requires some aditional hardware. Please read carefully the following requeriment list.
Requeriments:
- Line 6 HX STOMP
- Apple iPad + MIDI Designer 2 + this MIDI Layout
- Roland FC-300
- Roland UM-ONE MIDI Interface
- Yamaha MD-BT01 Wireless MIDI Interface
- Apple Lightning to USB 3.0 camera adapter
Making connections:
-Connnect the Roland UM-ONE MIDI DINs (In, Out) to the Roland FC-300, then plug the USB to the Apple Lighning to USB 3.0 camera adapter, plugged to your Ipad.
- Plug the Yamaha MD-BT01 to your HX Stomp, then connect Wirelessy once in MIDI Designer Pro 2
Features:
- Premapped SYSEX Mode to make both devices work seamlessly together.
- Offers control over five preset on the FX STOMP (1 to 5)
- Expression Pedals with real-time movement on the iPad screen.
-Bypass and Tuner functions assigned to the Footswitches under the Exp pedals (including On/Off LEDs)
- 3 FS assigned to Snapshots (One LED active)
- One FS to Switch Stomp and Preset Modes, that also works as Tap Tempo.
- 5 FS (lower row on the FC-300) with double function: single press to turn On/Off effects, Long Press to change presets 1-5
- Looper Controls onscreen
- Control over the FC-300 screen brightness and ECO mode.
Version 1.0 - Released 24-MAY-2020
Future versions may include additional features. All updates will be free of charge for current costumers.
This looks great!!!!!
Can you share more info?  Can we get to any info via a link?
Thanks for sharing eh.
It's already available, guys!!
This is the first version, offering Plug&Play functionallity over five presets (1 to 5)
Version 2, coming soon.
V2 Improvements:
— Selectors for each of the 5 footswitches dedicated to program changes
— Memory for 9 internal "Banks" (so, 9x5 presets)
— Four buttons for the HX Stomp modes included in the Looper view
— New "Credits" and "Connect" buttons
Covering the entire Roland FC-300 SYSEX specification plus the HX STOMP MIDI implementation to make them work seamlessly together. All plug&Play! Does not require any user configuration.
More than 1000 lines of Stream Byter code!
About 100 hours of single man work!
Full control over the Roland FC-300 onboard LEDs, 3-Digit Screen (showing preset numbers), LCD Screen (2 x 16 characters), and both Expression pedals, all synced with your HX STOMP!
Pena que en mi país el FC300 salga tan caro. Si sumo todo lo necesario para controlar la Stomp y evaluo el espacio que pcupa todo casi que me conviene mas tener una LT
