Modulation blocks- random rate?
davidfussell
Hi
Listening to the modulation blocks 'Double Take' and 'Ubiquitous Vibe', the perceived rate appears only in part of be attributed to the 'Rate' parameter setting - It's as if there's also an independent oscillator running which combines with the rate setting to create a random/cyclical 'beating' pattern- I'm hoping there something I'm missing, or do these effects operate this way by design?
Thanks for any assistance...
D
That is a brilliant observation. I heard the same thing with the exact same effects just recently. It is a beat or a glitch that's off from the setting in Rate/Note Sync. I use note sync, fwiw. I'll have to find a way to record it.
This is the only bug report so far that might be related to what I am experiencing:
