veka062
Helix Reamping in Ableton
Hi
I just need preferences for this. What to select in Helix an d what in Ableton. TNX
What exactly would you need to know? By default, USB Outs 1/2 deliver the full Helix shebang and USB 7/8 carry just the dry guitar DI signal. For reamping purposes you may want to record both, so you know what you played (from recording USB 1/2) and still have all the reamping options by using the dry signal that you recorded in parallel.
Actualy I want to record something and put it in a loop. Than continue to edit and make my preset. I found for now, only option to do this is Reamping metodh.
Is there any other option?
Why would you want something else?
For quick and dirty patch construction I'm using the onboard looper straight at the beginning of the signal path, for detailed "in context" editing I'm recording the dry signal and use Helix Native. When done, I drag the patch into the Helix Floor and do some final finetuning (such as setting up switches and the likes).
Btw, when you record the DI signal through USB outs 7/8, there's no point in recording stereo, so you could just record either channel 7 or 8 onto a mono track, saving some ressources.
