Stompbox M5 MIDI
epignatus
Hi, I need some MIDI setup in my M5.
The connection string is:
MIDI foot switch / MIDI OUT in M5 / MIDI IN - from M5 / MIDI OUT to Hughes & Kettner Tubemaister 36.
When operated with the MIDI footswitch, only the M5 switches and Tubemaister does not respond.
But when switching the M5 without using a MIDI foot switch, the Tubemaister also works.
When the MIDI footswitch is connected directly to the Tubemaister, the communication works. I checked it on all used MIDI cables.
M5 is set to MIDI channel OMNI. Is it possible that M5 does not support MIDI thru function? Or am I making a mistake somewhere?
Thank you for any help in solving this problem.
  • 1 month later...
