ezut Posted November 18, 2019 Share Posted November 18, 2019 I use the looper and want to change presets. It can be solved? Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 18, 2019 Share Posted November 18, 2019 1 hour ago, ezut said: I use the looper and want to change presets. It can be solved? Hi, IIRC, it is possible to change to another preset while using the looper, but both presets must contain the exact same type of looper. Therefore if you are using a 6 switch looper, then the target preset should also have a 6 switch looper available. Check this: Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 18, 2019 Share Posted November 18, 2019 Also, with the latest FW you can't stop the looper before you switch presets or you'll lose the loop. 1 Quote Link to comment Share on other sites More sharing options...
ezut Posted November 25, 2019 Author Share Posted November 25, 2019 Thanks 1 Quote Link to comment Share on other sites More sharing options...
