araymond213 Posted November 20, 2019 Share Posted November 20, 2019 Hi all, New HX Effect user here, first post. It seems there have been many threads regarding the quirks with the expression pedal but I haven't seen this one yet. My issue is that the expression pedal position seems to be affected by the state of another block - namely the Ext Amp control. When the Ext. amp button is off (clean channel on amp), the heel position only returns to 3%, not 0. When ON (overdrive) it does return to 0. This is especially problematic with whammy effects... I expect the heel position to be the unaffected note, but it's 3% sharp. I'm using a line6 EX-1 expression pedal connected with a short TS patch cable. I've tried to swap cables, same result. The result is also the same whether the amp is connect through the EXP 2 jack or not so it's not a grounding issue there. I suspect it may be an interference issue between the 2 EXP/Amp jacks? Anyone else experiencing this? I could make a short video to demonstrate. Thanks Quote Link to comment Share on other sites More sharing options...
refagaem Posted November 22, 2019 Share Posted November 22, 2019 Hi, i 've the same issue ( 3%) without using Ext. amp button.. HX Stomp is in a loop of my PBC switcher and an Exp pedal Boss (EV 30) is connected to PBC, piloting (in Midi) any effects like wha , whammy, reverb etc.. i've regurlarly to re-calibrate the EV 30 in the PBC, so i'm also curious to know what's the issue wich is very boring specially with whammy. Thanks Quote Link to comment Share on other sites More sharing options...
