Legacy reverbs are all stereo
Indianrock2020
Our PA is strictly mono and I run direct from Helix to PA out of the left/mono XLR output.   So I decided to review my patches and found I often had the last block as a stereo LA Studio comp, which was often preceded with a stereo legacy reverb.  The newer reverbs can be switched to mono.   This isn't likely to cause a problem since the output is summing to mono, but I have heard of some stereo effects producing something unexpected when summed.  Someone also mentioned that the summing process added  3 decibels --- if that is happening when I play live but not reflected over USB to my DAW, it would be nice to know.
21 hours ago, SaschaFranck said:
I'd simply add a mono gain block as the last one. That way you'll listen to the patch as it will run into the PA, regardless of how you connect the Helix. You can as well switch the compressor to mono.
Yes that’s a good work around but at this level, should it really be necessary to have to waste a block for something (Summing to mono) that should have been part of the effect parameter set from the beginning?
I think it should be possible to set all outputs to mono straight on the output "blocks".
As far as the legacy FX all being stereo goes, well, they're legacy and L6 probably don't want to spend more time with them. I for one think it's quite nice they were added at all.
Was delighted to see the new HX mono reverbs added a few firmware revisions ago but I would like to see Line6 provide new HX mono versions of at least a plate, room, and hall reverb. Other new mono reverbs would be welcome too but these would be a good start. Mono HX reverbs use less DSP and after four years of being out in the wild the Helix is primed to finally receive these meat and potato reverbs.
Defenitely (especially in case they'd be using less CPU resources, which should be expectable). These are exactly what I'm using the legacy reverbs for, because the genuine HX ones aren't too useful for plain vanilla reverberage.
11 minutes ago, brue58ski said:
I don't know if thisi still true but some of them summed the input to mono and then output a stereo reverb image.
They maintain stereo separation on the dry side, but remember stereo processing doesn't mean that each side is processed on it's own. If you, for example, mute the right side going into a reverb block, there will still be wet output from the left and right sides.
14 minutes ago, brue58ski said:
I'm still trying to find the list of what each reverb is. AND, has this been changed? Are they all True Stereo in the Helix?
I don't think any of those diagrams completely represent what's happening with the stereo effects in the Helix. The one labeled "Stereo THRU/Stereo FX Block" is closest. The difference would be the mix control. There's only one, so you can't control the mix for the left and right side independently.
These only represent the legacy reverbs which is what the subject was about.
Yeah, I’m saying that’s not quite how the Legacy reverbs work in the Helix. It’s not really how they work in the HD series either, fwiw.
The Legacy reverbs behave the same way as the Stereo HX reverbs as far as the audio processing.
That wasn't my experience as I recall, with the HD series. That's why that document that I linked to was created. As far as Helix goes, that's good news. I haven't tested them to see, so total stereo is a good thing.
14 hours ago, hideout said:
Why can't a "summing amplifier" be added at the end of the signal chain within each of the reverb effects themselves?
You can use anything that's mono. You could just add a mono volume pedal after each reverb. That would be pretty much the least amount of DSP used to get this effect.
I use a mono Cali IV EQ as the last thing in all my live patches. Sorted. I like the idea of an overall EQ per patch (not global, I use that for different purposes) anyway. Would perhaps be nice to have the legacy stuff running in mono genuinely, though, as it might save some CPU cycles.
Yes, but that occupies a block that could otherwise be used for something else.  That's a workaround that, had a little forethought been used, really shouldn't be necessary.  Also, what if there's no room for another block in that signal chain?
  • 2 years later...
On 12/6/2019 at 3:43 PM, Indianrock2020 said:
Someone also mentioned that the summing process added  3 decibels.
They were probably referring to what happens if the audio in the left and right channels is the same. Summing the left and right channels when they differ, which should be the case with stereo reverb, does not produce the same end result.
Tech talk for those who want to put on their lab coats: Summing the left and right channels to mono is what produces the "mid" in mid-side processing. The sides are still present, but the mid is boosted somewhat compared to the sides. However with the sides, the mid cancels completely.
