vowitzel
Switch model amp and pre amp
Hi everyone
I have my HD500x connected to a stacked amp via 4 cable method.
i would like to create a preset that allows me to switch between real and modeled amp.
i understand the magic must be with the send/return FX unit. Can’t get it working though.
any ideas or hints?
thx
program a Footswitch to toggle the Amp Model ON and the FX Loop OFF....The inverse is AMP Model OFF, FX Loop ON...Put cursor on the AMP and hold ENTER...set the FS you want to use make sure amp is ON...move the cursor to the FX Loop block....set the FS to be the same as the AMP....insure the FX Loop is off (click ENTER to toggle ON/OFF)....click View to leave the FS screen...confirm the toggle and save the patch.
thanks @spaceatl!
Sounds like a workable solution but not sure if I can still use FXs with this approach when using the real amp.
Anyhow - will try that out and report back once my POD is back from repair (footswitches).
Don't worry. It will work perfectly 100% guaranteed.
_______________________________________________________________________________________________________________________________________________________________________
All about POD HD500/X
help and useful tips
:-) can’t wait to get the gear back and try out.
could try it out finally. Works like a charm!  A big Thanks folks.
