Snapshot Bypass - being set to default when copy/pasting a preset
NielsO
Hello, I am a glad owner of a HX Stomp
But i have a problem with blocks that I have set to NOT be turned ON or OFF by snapshots, then be switched back to DEFAULT (being turned ON or OFF by snapshots), when importing presets and copy/pasting presets. It's quite annoying that it doesn't seem to copy if the blocks are set to Snapshot Bypass or not...
Have anybody else encountered this problem??
My scenario: I have just played a Musical, and when practicing the songs we were going to play I used a real amp in the room, but when we moved in to the place we were going to preform, I was going to use a modeled amp and in-ears. It worked very well!! I just made the presets with the "amp and cap block" bypassed and set to not turn ON by the snapshots. Then when we moved, I could just turn the amp block on and save the preset (no problems yet). I then exported the setlist, so I could use any HX stomp, if my unit started malfunctioning. But if I import that same setlist, the Snapshot Bypass gets reset... So, when I switch between snapshots, the amp gets turned OFF and ON, after being copied and pasted...
Thanks in advance:)
  • NielsO changed the title to Snapshot Bypass - being set to default when copy/pasting a preset
