tmingle Posted December 18, 2019 Share Posted December 18, 2019 I seem to run out of processing power pretty easily on this unit. I do realize that there is a 6 block limit. I assume it does not have the same processor as the larger units. Is this true? I try to run 2 IR blocks like a lot of vids & cant. I run a pretty basic chain, 808, amp, reverb, IR & EQ. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted December 18, 2019 Share Posted December 18, 2019 Some amps use up more DSP than others, and the IR's can chew up a lot, too... but the amp model is usually the biggest DSP hog. Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 18, 2019 Share Posted December 18, 2019 Note that you can only run two IRs if both of them are 1024 sample blocks. You can't load two 2048 blocks. Quote Link to comment Share on other sites More sharing options...
tmingle Posted December 18, 2019 Author Share Posted December 18, 2019 12 minutes ago, phil_m said: Note that you can only run two IRs if both of them are 1024 sample blocks. You can't load two 2048 blocks. Thanks. I'll give that a try Quote Link to comment Share on other sites More sharing options...
Ed_Saxman Posted December 18, 2019 Share Posted December 18, 2019 4 hours ago, tmingle said: I seem to run out of processing power pretty easily on this unit. I do realize that there is a 6 block limit. I assume it does not have the same processor as the larger units. Is this true? Same DSP, but only one of them, unlike the bigger units. And artificially limited to 6 blocks. The HX Effects also have a single DSP, but it’s not limited (well, something like up to 9 blocks?) The 6 blocks limitation on the Stomp seems to be logical to some extent, since some amps alone needs >50% of the DSP. They also mentioned reasons related to the interface, ease of use, future updates, etc On the other side, is a real drawback when some FX with virtually no DSP usage (FX loop, or the looper itself) can’t be added to the chain without wasting a block, despite having enough free DSP. Quote Link to comment Share on other sites More sharing options...
