Fender Tone Master amp connection with HD500X
ghtheblues
Hi I'm not sure if this is the right place but I can't fine any info after multiple searches.
I have a Fender Twin Reverb Tone Master amp that I want to use with my HD500X. The amp doesn't have an Effects Loop option. It does have XLR out(with or without cab simulation) but I don't know if or how I can connect it to the HD500X. I want to be able to use the AMP in the signal chain so I'd like some  ideas of the ways I can connect.
OK after having a closer look at the POD there's an AMP switch so I can go straight to the AMP input jack from it and used the POD as stomp box before the AMP. That's pretty much what I was after.
Edited by ghtheblues
figured out problem but may be other solutions
