Retro-Rick
String Volume Not Changing Per Snapshot - Solved!
Hey Guys, I've been trying to make a helix preset where the string volume changes from snapshot to snapshot, and can't seem to make it work.
In my case I'm trying to go from a Open G# with string 6 at volume 0% on 3 snapshots, to a standard tuned guitar with all strings 100% volume on the 4th snapshot.
The tuning changes fine per snapshot, but the string volume remains at 100%. I know I can work around this through workbench, but I shouldn't have to, it's supposed to work.
My input variax setting is - "per preset". I've checked every global setting and have found nothing that should effect it. Guitar is JTV59, flash memory 2.23, Helix 2.82.
Has anybody made a preset with snapshots changing string volumes?
I noticed, if I leave the preset, and return, it works temporarily, the 6th string is dead (which is what I want) in snapshot 1... But as soon as I go to any other snapshot,
the volume goes back to 100% on all the snapshots.
Do you have the String Volume parameters assigned to the Snapshot Controller?
Thanks again, Yes I do, the string volume of the 6th string in brackets, and I confirmed it's controlled by Snapshots. I think it's a defect in the software.
If I had a modern (JTV or newer) Variax I would test this for you... but sadly my Variax is 1st generation so it won't respond to volume changes.
Have you checked the JTV forum? Maybe it is discussed there?
On a side note... what part of Canada are you located?
I'm mainly at home north of Toronto in Innisfil, but I also maintain a small residence in the West Island of Quebec (I go there a lot).
How about you... Are you Canadian?
Yes, I'm in Winnipeg.
I lived in Winnipeg in the 80's, Salisbury House nip cheese burgers were amazing...  :P
Update - Problem solved, I opened a ticket, turns out my Variax needed to be re-flashed.
