mtumi
Replicating a DD-3 stutter effect
Hi
trying to replicate a DD-3 stutter effect, as shown below. Any advice?   I’ve found that the pedal seems to retain previous feedback when i cut it on, off, and on again, so while I might get a good start towards this sound the first time, it progressively turns to chaos as I try it more than once, due to the feedback from previous tries sticking around.
Assign the same footswitch you use to turn it off and on to your feedback level so it goes to 0 when you turn it off and goes to the level you want when you turn it on. I think that may solve the issue
Ah That’s smart.   That should work.  I forgot you could do that.  Thanks!
In the end I got this working pretty well, and with an aux momentary pedal instead of an expression pedal.  The stomp is a deep and amazing machine!
