Ratchet9868 Posted December 30, 2019 Share Posted December 30, 2019 Is there any way to keep the delay going after a preset switch? Quote Link to comment Share on other sites More sharing options...
hurghanico Posted December 30, 2019 Share Posted December 30, 2019 The only way to keep the delay going after a rig/chain change is by building 2-patches-in-1 presets, ie by taking advantage of the 2 parallel paths to make 2 different rigs, and making them mutually exclusive. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted May 28, 2020 Share Posted May 28, 2020 Yes you can do that : Create a patch on channel A with a volume pedal at the end with setting min to 0 and max to 100 Create a patche on channel B With a volume at the end with setting min to 100 and max to 0 Use the pedal to switch between the 2 channels Quote Link to comment Share on other sites More sharing options...
sorcerer532 Posted June 19, 2020 Share Posted June 19, 2020 On 5/28/2020 at 4:00 PM, Punkyboy said: Yes you can do that : Create a patch on channel A with a volume pedal at the end with setting min to 0 and max to 100 Create a patche on channel B With a volume at the end with setting min to 100 and max to 0 Use the pedal to switch between the 2 channels You can assign the expression pedal to each amp model's CH VOL. When Amp A is at playing volume, the CH VOL of Amp B is 0, and vice versa. The heel and toe position give you two "channels." This also frees up blocks. If you're effects aren't too heavy on DSP, it is possible to have effects models on all 8 blocks. *As long as the delay is after the amp model on Path A or B, you will hear the tail ring out when you switch channels. Quote Link to comment Share on other sites More sharing options...
